Hľadať • Registrovať •
FAQ •
Anjeli •
Pravidlá •
Rapid Link
• Prihlásenie
Stránka 1 z 1
[ Príspevkov: 4 ] |
samuro
Registrovaný: Str, 14.03.2012, 1:45 Príspevky: 219 Bydlisko: Rožňava
Zdravím chlapi chcem sa spítať či má niekto skusenosti z výmenov hlavy na samurai-i z 8v na 16v po pripade či to aspoň pasuje Ďík
_________________ Čím viac upravené auto ,tým ďalej sa ide po traktor "
| Ned, 22.12.2013, 21:59 |
Samik1300JX
Registrovaný: Pon, 19.12.2011, 23:09 Príspevky: 261 Bydlisko: Trenčín
Teoreticky by malo. Ale treba dať pozor na zdvih a chod ventilov aby nedošlo k stretu piest ventil.
_________________ 2x Samurai pozitív
| Pon, 23.12.2013, 17:34 |
Samik1300JX
Takže som googlil The SOHC 16-valve G13BB (introduced in March 1995) has electronic MPFI Multi-point fuel injection, generating 56–63 kW (76–86 PS) and 104–115 N·m (77–85 lb·ft).[1] Later G13BBs have two coil packs bolted directly to the valve cover, although early models still had the coil packs mounted to the left side of the head - where the distributor was traditionally located. This engine uses a MAP sensor to monitor manifold pressure, unlike the G16 series. This engine has a non-interference valvetrain design. It uses the same G series block found in many other Suzuki models and so it is a popular conversion into the Suzuki Sierra/Samurai/Jimny 4WD, which uses either a G13A (85-88) or G13BA(88.5-98). This allows the engine to fit into the engine bay simply as engine and gearbox mounts are identical and both engines are mounted North-South. Preložet mu to niekto prosim. Môj english skill je na to nízky
| Pon, 23.12.2013, 17:37 |
samuro
ked som to dobre pochopil tak bloky by mali biť tie iste . dokonca u novších samurajov je blok g13bb tak a už začínam velmi uvažovať
| Pon, 23.12.2013, 18:45 |
Stránka 1 z 1
[ Príspevkov: 4 ] |
