Zobraziť témy bez odpovede | Zobraziť aktívne témy Aktuálny čas je Uto, 09.06.2026, 15:38
Dnes je utorok 9. júna 2026, meniny má Stanislava a zajtra Margaréta
Odpovedať na tému  [ Príspevkov: 54 ]  Choď na stránku 1, 2, 3, 4  Ďalší
 Nissan Consult
Tak sme sa dnes dohodli s patrolom, ze bude hlasit co sa v nom deje.
Ked stojime na volnobeh
Ked jazdime
Hlasinie chyb
Patrol GR Y61, 2,8TD
Štv, 26.08.2010, 12:00
:shock: :shock: :shock:
Vo co kráčí???
Štv, 26.08.2010, 14:42
Nissan Consult Interface - diagnostika pre Nissan s tymto konektorom
Misovi sa podarilo rozchodit moj smejd z Taiwanu, a teraz sa hra ... :-D
Podporovane SW: DDLreader v.16c, ConZult, ScanTechNissan, Z-Control, SRTalk v.1.0, CSetup v.2.0, ZTalk v.1.1, Nissan Data Scan v.1.4, Nissan Data Scan v.1.51, a ine
Naposledy upravil finder dňa Štv, 26.08.2010, 15:18, celkovo upravené 1
Štv, 26.08.2010, 15:13
...som ani netušil, že to 2,8 má takto riešené
Zatial som nasiel iba jeden SW spolupracujuci s RD28EFI a to http://www.ecutalk.com/. Ostatne sa sice s ECU spoja ale asi nemaju spravne namapovane senzory - nic neukazuju. Ecutalk vie sledovat:
ZD30: Spill Valve, Barometer, Inj Timing CV, RPM-Pump, VNT SV 1
RD28: C/Sleeve Pos, Act Inj Timing, Inj Timing CV, RPM-Pump
TD27: Target F/INJ, C/Sleeve Pos, Act Inj Timing, Inj Timing CV, RPM-Pump
TD42: Barometer, RPM-Needle Lift, IC INT/A Temp, Act Inj Timing, Inj Timing CV
so in terms of most common sensors:
Inj Timing CV - all
Act Inj Timing - all bar ZD30
RPM-Pump - all bar TD42Ti which has RPM-Needle-Lift instead, but this additional RPM is pretty useless.
C/Sleeve - RD28/TD27
Barometer - ZD30/TD42
Spill Valve, VNT SV1 - ZD30 only
RPM-Needle Lift - TD42 only
these are the current readings not supported by diesel:
xx.xL/100KM, INJ% - will leave as-is as in hope eventually we can get some kind of fuel stuff
1) xxºB - timing - replace with actual inj timing -xxº (all bar ZD30), and spill valve(xxCA) or VNT SV1 (xx%T) for ZD30? - isnt much room for anything to explain the reading.
2) AAC: xx - replace with ICV:xx%
3) O2:.xxV - replace with CS:x.xV (RD28/TD27) or Barometer (xxxxhPa) for ZD30/TD42
Teraz uz viem ze vahu vzduchu mam OK. :-D
Nasleduje pokus o instalaciu na PDA IPAQ 214.
Štv, 26.08.2010, 16:18
Mišo, nestačím sa diviť. Nakoniec mi ešte budeš môcť skontrolovať aj tú moju zdechlinu :-D
Mám bobky pred Slavkovom, ale čo už, cúvnuť sa nedá, tož kára musí na diagnostiku počkať. Slavkov je Slavkov.
Štv, 26.08.2010, 16:29
Som doma. Dohodni s Finderom zapozicanie, dones notebooka so seriovym portom, nainstalujeme SW a mozes testovat aj na Slavkove.
Štv, 26.08.2010, 16:42
No, na toto som ja ešte nedorástol. To radšej pod odbornou kontrolou. :-D
Štv, 26.08.2010, 16:44
Neboj, pripojime notebboka, naistalujeme SW a uz iba na monitore sledujes co sa v realmom case s motorom deje. :-D
Štv, 26.08.2010, 16:49
No, pred Slavkovom to už nestihnem...ale dobrý nápad odsledovať, čo to urobí, keď polejem motor vodou :-D lebo to zatiaľ nikto netuší, čo sa tam deje.
Určite sa ozvem. Teraz idem montovať kryt olejovej vane.
Štv, 26.08.2010, 16:55
Registrovaný: Ned, 28.06.2009, 18:12
...fiha..no toto.....to mi najde chybu?ked niečo nafigu..hm?
Volvo BL71 4x4
PROFIbager 0917 951 340
OFFROAD:
" ...žiadny teren nieje nezdolatelny..."
http://www.youtube.com/watch?v=dTO6uDiEq14
Štv, 26.08.2010, 18:53
Na Y60 nie.
Uz som nasiel aj ako dobastlit USB Host na Ipaq 214, uz zostava najst iba prevodnik USB / RS232 s cipom FTDI232 a ficime aj na PDA. :D
Štv, 26.08.2010, 19:09
Tak to mam rozbehane aj na PDA HP IPAQ214.
Uto, 21.09.2010, 16:23
Mišo, aký HW to potrebuje, myslím napr. notebook, keď ti to ide aj na PDA? Šlo by to s prevodníkom USB/RS232 aj na notebooku?
A, pravdu povediac, tie skratky mi vo vzájomnej kombinácii nie sú až také jasné...
Uto, 21.09.2010, 16:38
Islo. Tie skratky som vsetky este nenastudoval.
Uto, 21.09.2010, 16:47
